OEM and AfterMarket Fuel Pressure Regulator thread
butters607
Aftermarket Fuel Pressure Regulator
Just wondering if we can get some info and pics from guys out there that have done this what brands you recommend how to adjust it for different setups and what not. All info is appreciated thanks!
Torspd Edit ******
Alright, here is the picture of how to run the vacuum line, when doing the OEM FPR MOD.
Thank you dpartinvr4 for the picture. :top:
If you also have a boost gauge, you Tee into that line for the boost gauge.
Here is a link to our vendor DEZOD who also carries fuel pressure regulators, and fuel rail adapters.
http://www.dezod.com/pd-aem-fuel-pressure-regulator-universal.cfm
Support our vendors, and give Paul at Dezod a call if you have more indepth questions. :top:
Toon714
Tomei fpr
Just put on a gauge on the side of the fpr where my pro efi fp sensor is and adjust it from the top of the tomei fpr.
butters607
Tomei fpr
[/QUOTE
got a pick where it mates to the fuel rail?
butters607
is it a universal adapter or? Also is the fuel pressure regulator adjustable or is it self adjusting?
Toon714
The adpater Is for toyota and nissan.
I put the link for u for the adapter up top.
Yes the fpr is adjustable. U have to adjust it your self.
Good info, I have been trying to find out what fittings would be needed to use one of these, since my factory one is shot.
Whitebeauty
Figured i put this here since boosted folks would more than likely need more fuel anyways and give Torspd something to start off of then he can sticky it.
We should put the Fpr mod here, the tomei one and also the aeromotive one..
Amo-cat3
Whitebeauty, I was waiting for you to start a thread on this. Sounds good to me. I've been looking at the Tomei L but is a little pricey. I read on a website that they were being dicscontinued. I am going to just tee off of my boost vacuum line to my stock fpr for now.
To complete this mod you need:
An aftermarket fuel pressure regulator (Tomei or Aeormotive)
Fuel rail adapter
fuel pressure guage
vaccuum hose?
Just starting a list. Gotta find pics.
Whitebeauty
Heres the Tomei L.
Whitebeauty
Ive had it for awhile. Not sure if im gonna use it though. If i need to up the fuel press. Then i'll put it on.
Amo-cat3
Also looks like we need extra fuel line. Stainless steel braided line - how much extra do we need?
Doesn't have to be braided. That is just a preference. I currently have aeroquip push lock hose on mine. About 5-6 feet. Take a quick measurement, and get a little extra for routing.
3/8" hose will slide over the steel return line, at the fender well on the driver side. That is also known as -6 AN.
Whitebeauty
Post up a pic Mark.
Toon714
This is wat ur gonna need to install the fpr.
7ft of starlight hose, 3- 6an fittings, 1 straight, 1 90 And the tomei adapter for the stock.rail.
the gauge on the fpr for adjusting.
Installed
