boneman840
- Jan 14, 2007
- 262
SignUp Now!Does anyone know how accurate the Scangauge 2 is? I checked it when i got back from Xfest and it said I hit 129mph max speed! I just don't know how accurate they are.None the less it did bring a smile to my face.:biggrin:
:top: we were definately haulin azz down I-4 the speedo needle was about an inch past the 120 mark! :rock: :driver: Don't know if I actually hit 129 but I will go with the scan gauge and have happy thoughts.:biggrin:
should you be going that fast in the first place???That can definitely happen. The Scan Gauge is actually a good thing to have cause once you pass the 120 mark on the speedometer...you just have to guess. Just don't throw it into 6th cause it will bring you back down. :thumpdown:
Well there is a way to adjust the scan guage to calibrate/correct it for different size tires or adjust it slightly one way or another (+/-). I adjusted mine to read as much as 15 miles off....
But then again I know the X will go fast then 124.... but Im not to sure anyone else here will buy it. :top:
I normally wouldnt go that fast but when 2 ricers go flying by you got to represent:driver:
