spark plugs
SWB X
Lookin to change my plugs. I have 33k on them. any suggestions.
thanks in advance.
RJ
I went with denso from toyota. Dont be surprised when you replace them - one side was ngk other was denso. When I talked to the toyota rep about ti he said the heads are put together and pre loaded with the plugs before they are bolted to the block. Seems like they could label them somehow.
Its no biggie , just thought I would give you a heads up.
Dont forget to use anti seize on your new plugs.;)
SWB X
11.$ per plug. No way..it wont make that much of a difference.......Will it?
I bought the regular Denso's from Toyota. they are $6.00 ea, and are nice.
I didnt have 2 different types of plugs, I had NGK in both sides.
Spyder327
I believe its because iridium are changed every 90k instead of 30k, so they last you longer.
Zigen
I have always used NGK.... I wonder why they used 2 different brands.. What is anti seize? I have never used that when changing my plugs...
My 3000gt used iridium because it was such a pia to change the plugs on it because the whole intake plenum had to be removed and it took about a total of 3 hrs just to change the damn plugs.. i think iridium are suppose to be replaced every 60k
rpmspeedyblue
NGK and Denso are pretty close to being the same plugs. Anti seize is a lubricant for the threads of spark plugs, so it will be easier to take out on the next change. Some just use anti freeze on the threads.
DrEaM MaKeR
if you dont like too mess with the plugs get iridium because they last longer but if it don't bug you then just stay stock they are cheaper and if you change them every 30k they will give you the same performance.
http://www.customtacos.com/vb3/showthread.php?t=55927
SupraJunky101
Holy crap, plugs lasting 60K miles ?
I changed the plugs on my supra every 3K miles. This truck this is going to take some getting used too :p
What kinda plugs where you using? Plugs should last longer than 3k, if not then you have a problem with your fuel, detonation or something. :hmmmm2:
SupraJunky101
NGK 6097's, Big single, 680cc Injectors. They were the only plug that I tried that actually gave me some form of an idle and didn't break up at high rpm (8000+)
Theoretically they should of lasted longer but after ~ 3K miles they were toasted. The car still ran fine, idle'd fine but the plugs were toast and once changed you could feel the diffrence. The 1JZ is a tricky motor when it comes to plugs.
