Started dyeing my interior today.
I really don't like the three tone interior in my truck so I decided I would try something different. I decided to get some of that interior dye (black) and start experimenting. I know people who have used this dye in older cars and the had very good results. I only got the console and A pillars and headliner done today. It looks freaking awesome in person. The pictures make the parts look more shiny than they do in person. I will take better daylight pictures when I get it completed. I am planing on dyeing everything the same color except the silver rings around the gauges and heater controls. If I screw it up and it looks like crap when I am done then I am off to trade it off for something bigger. I seriously doubt that will be the case because everything I have done so far looks sweet.:top:
Anybody know of a dash disassembly write up or pictures of the dash being disassembled
hiflyer
I have a wack on PDF's on the Tacoma - forget where I got them from...
I can post, but it's 40MB zipped - includes whole interior dissassembly
PM me, and i'll send you the link
this is the contents:
| 2005_tacoma_alignment_4x4_prerunner.pdf
| 2005_tacoma_alignment_front_4x2.pdf
| 2005_tacoma_foglight_adjustment.pdf
| 2005_tacoma_headlight_adjuustment.pdf
| 581PA11TOY.PDF
| Cab_Mount_Bolt_TSB.pdf
| Exhaust_TSB.pdf
| JBL_System_Diagram.pdf
| Leaf_Spring_TSB.pdf
| list.txt
| Overfender_Refinish_process_TSB.pdf
| TacomaParts.pdf
| Tacoma_Audio_Non_JBL.pdf
| torque_specs_front_suspension.pdf
| torque_specs_rear_suspension.pdf
| Toyata_Scion_Vin_Decoder.pdf
| truck manuals.zip
| V1OwnersManual_2005-i4.pdf
+---1grfe_2005_Tacoma_Engine_highlevel
| 1grfe.pdf
| 1grfe_eng.pdf
| 2005-tacoma-engine-oil-cooler-oilcoolerassy.pdf
| 2005-tacoma-oil-pressure-sensor-parloc40.pdf
+---2005_tacoma_a750e_f_Auto_Tran_diag_repair_cmplt
| | 12264-help-filling-transmission-fluid-a750e.pdf
| | 12265-help-filling-transmission-fluid-a750f_4x4.pdf
| | 2005 tacoma-automatic-transmission-oill-automatic_transmission_components_a750e.pdf
| | 2005 tacoma-automatic-transmission-oill-automatic_transmission_components_a750f.pdf
| | 2005-tacoma-trans_oil_cooler.pdf
| | atf_inspection_1gr-fe.pdf
| | comp1grf.pdf
| | comp2uzf.pdf
| | comptps.pdf
| | comp_cs.pdf
| | equia750.pdf
| | insp_tcc.pdf
| | inst1grf.pdf
| | inst2uzf.pdf
| | insttps.pdf
| | inst_cs.pdf
| | lubra750.pdf
| | oper.pdf
| | ovra750e.pdf
| | ovr_plp.pdf
| | ovr_pnp.pdf
| | ovr_ss.pdf
| | ovr_temp.pdf
| | ovr_vb.pdf
| | prec.pdf
| | rectooa7.pdf
| | remo1grf.pdf
| | remo2uzf.pdf
| | remotps.pdf
| | remo_cs.pdf
| | serdata7.pdf
| | ssta750e.pdf
| | torspea7.pdf
| +---diagnostics
| | basinsa7.pdf
| | cia75.pdf
| | cia750.pdf
| | cia750ea.pdf
| | cia751.pdf
| | cia7510.pdf
| | cia7511.pdf
| | cia7512.pdf
| | cia7513.pdf
| | cia7514.pdf
| | cia7515.pdf
| | cia7516.pdf
| | cia7517.pdf
| | cia7518.pdf
| | cia7519.pdf
| | cia752.pdf
| | cia7520.pdf
| | cia7521.pdf
| | cia753.pdf
| | cia754.pdf
| | cia755.pdf
| | cia756.pdf
| | cia757.pdf
| | cia758.pdf
| | cia759.pdf
| | cmpa750e.pdf
| | cpaca750.pdf
| | dcca750e.pdf
| | diasysa7.pdf
| | dlata750.pdf
| | dota750e.pdf
| | dtcca750.pdf
| | fsca750e.pdf
| | htpwta75.pdf
| | hydtesa7.pdf
| | inita750.pdf
| | locaa750.pdf
| | lodama75.pdf
| | mdpa750e.pdf
| | msta7.pdf
| | msta750e.pdf
| | preca750.pdf
| | psta750e.pdf
| | roatesa7.pdf
| | sysdesa7.pdf
| | sysdiaa7.pdf
| | terecma7.pdf
| | tpasnla7.pdf
| \---Repair
| abbrevia.pdf
| conponen.pdf
| conponen2.pdf
| conponen3.pdf
| conponen4.pdf
| glossary.pdf
| howto.pdf
| howtodet.pdf
| howtouse.pdf
| precaud4.pdf
| repairin.pdf
| serviced.pdf
| specifie.pdf
| sstspeci.pdf
| torquesp.pdf
| w040001.pdf
| w0400012.pdf
| w0400013.pdf
| w0400014.pdf
+---atf_inspection_1gr_fe
+---audio
| antennacordsubassy_replacement.pdf
| avsys_components.pdf
| avsys_inspection.pdf
| avsys_onvehicle_inspection.pdf
| avsys_precaution.pdf
| frontno1spkrassy_except_regcab_replacement.pdf
| frontno1spkrassy_regcab_replacement.pdf
| frontno2spkrassy_replacement.pdf
| pulltopantennapolesubassy_replacement.pdf
| radioreceiverassy_replacement.pdf
| radiosettingcondenser_1grfe_replacement.pdf
| radiosettingcondenser_2trfe_replacement.pdf
| rearspkrassy_accesscab_replacement.pdf
| rearspkrassy_doublecab_replacement.pdf
| steeringpadsw_lh_replacement.pdf
| wboxspkrassyno1_replacement.pdf
| wholderantennaassy_replacement.pdf
+---Audio_and_Electrical
| problemsymptomstable.pdf
| radioreceiverpowersourcecircuit.pdf
| radiosettingcondenser_1grfe_components.pdf
| radiosettingcondenser_2trfe_components.pdf
| radireceivercomponents.pdf
| rearspeaker_accescab.pdf
| rearspeaker_components_dcab.pdf
| rearspeaker_installation_dcab.pdf
| soundsignalcircuit.pdf
| soundsignalcircuit2.pdf
| speakercircuit.pdf
| steeringpadswitchcircuit.pdf
| steeringpadswitch_components.pdf
| steeringpadswitch_installation.pdf
| systemdiagramdescription.pdf
| troubleshooting.pdf
| voltageinverter_components.pdf
| voltageinverter_inspection.pdf
+---Interior_Disassembly
| accessdoor_adjustment.pdf
| accessdoor_components.pdf
| accessdoor_overhaul.pdf
| backdoormoulding_subassy_outside_lh_replacement_xrunner.pdf
| backwindow_components.pdf
| backwindow_replacement.pdf
| frontbumpercover_components.pdf
| frontbumpercover_replacement.pdf
| frontbumperextension_lh.pdf
| frontdoorglassweatherstripassy_outer_lh_components.pdf
| frontdoorglassweatherstripassy_outer_lh_replacement.pdf
| frontdoor_wo_powerwindow_adjustment.pdf
| frontdoor_wo_powerwindow_components.pdf
| frontdoor_wo_powerwindow_overhaul.pdf
| frontdoor_w_powerwindow_adjustment.pdf
| frontdoor_w_powerwindow_components.pdf
| frontdoor_w_powerwindow_overhaul.pdf
| frontfendermudguard_lh_replacement.pdf
| frontfenderwheelopeningmoulding_lh_replacement.pdf
| frontseatinnerbeltassy_lh_bench_components.pdf
| frontseatinnerbeltassy_lh_bench_replacement.pdf
| frontseatinnerbeltassy_lh_separate_components.pdf
| frontseatinnerbeltassy_lh_separate_replacement.pdf
| frontseatinnerbeltassy_rh_separate_components.pdf
| frontseatinnerbeltassy_rh_separate_replacement.pdf
| frontseatouterbeltassy_lh_accesscab_components.pdf
| frontseatouterbeltassy_lh_accesscab_disposal.pdf
| frontseatouterbeltassy_lh_accesscab_replacement.pdf
| frontseatouterbeltassy_lh_doublecab_components.pdf
| frontseatouterbeltassy_lh_doublecab_disposal.pdf
| frontseatouterbeltassy_lh_doublecab_replacement.pdf
| frontseatouterbeltassy_lh_regcab_components.pdf
| frontseatouterbeltassy_lh_regcab_disposal.pdf
| frontseatouterbeltassy_lh_regcab_replacement.pdf
| frontspolilercover_ctr_replacement_xrunner.pdf
| frontspolilercover_lh_replacement_xrunner.pdf
| headlining_components_accesscab.pdf
| headlining_components_doublecab.pdf
| headlining_components_regcab.pdf
| headlining_replacement_accesscab.pdf
| headlining_replacement_doublecab.pdf
| headlining_replacement_regcab.pdf
| hoodbulge_replacement_xrunner.pdf
| hood_adjustment.pdf
| hood_components.pdf
| hood_overhaul.pdf
| innerrearviewmirror_inspection.pdf
| innerrearviewmirror_replacement.pdf
| instrumentpanel_meter_components.pdf
| instrumentpanel_meter_overhaul.pdf
| instrumentpanel_meter_precaution.pdf
| instrumentpanel_meter_replacement.pdf
| mechanism_for_ folding_components_frontseatrh_separate.pdf
| mechanism_for_ folding_overhaul_frontseatrh_separate.pdf
| nameplate_replacement.pdf
| outerrearviewmirror_lh_components.pdf
| outerrearviewmirror_lh_replacement.pdf
| powermirrorcontrolsystem_inspection.pdf
| powermirrorcontrolsystem_location.pdf
| powermirrorcontrolsystem_problemsymptomstable.pdf
| powermirrorcontrolsystem_systemdiagram.pdf
| quarterpanelmudguard_rear_lh_replacement.pdf
| quarterpanelwheelopeningmoulding_lh_replacement.pdf
| quarterwindow_rr_lh_accesscab_components.pdf
| quarterwindow_rr_lh_accesscab_replacement.pdf
| rearbodysidepanelprotector_lh_replacement.pdf
| rearbumperbar_components.pdf
| rearbumperbar_replacement.pdf
| rearbumperspoiler_lh_replacement_xrunner.pdf
| reardoorglassweatherstripassy_outer_lh_components.pdf
| reardoorglassweatherstripassy_outer_lh_replacement.pdf
| reardoor_adjustment.pdf
| reardoor_components.pdf
| reardoor_overhaul.pdf
| rearseat3pointbeltassy_inner_accesscab_replacement.pdf
| rearseat3pointbeltassy_inner_doublecab_replacement.pdf
| rearseat3pointbeltassy_outer_accesscab_components.pdf
| rearseat3pointbeltassy_outer_accesscab_replacement.pdf
| rearseat3pointbeltassy_outer_doublecab_components.pdf
| rearseat3pointbeltassy_outer_doublecab_replacement.pdf
| rearseatbeltassy_outercenter_doublecab_components.pdf
| rearseatbeltassy_outercenter_doublecab_replacement.pdf
| rearseatinner_w_beltassy_lh_doublecab_replacement.pdf
| rearseatshoulderbeltguide_lh_bench_components.pdf
| rearseatshoulderbeltguide_lh_bench_replacement.pdf
| rockerpanelmoulding_lh_replacement_xrunner.pdf
| rockerpanelmoulding_rear_lh_replacement_xrunner.pdf
| roofdripsidefinishmoulding_lh_replacement.pdf
| seat_components_bench.pdf
| seat_components_frontseatlh_separate.pdf
| seat_components_frontseatrh_separate.pdf
| seat_components_rearseatlh_doublecab.pdf
| seat_components_rearseatrh_doublecab.pdf
| seat_components_rearseat_accesscab.pdf
| seat_overhaul_bench.pdf
| seat_overhaul_frontseatlh_separate.pdf
| seat_overhaul_frontseatrh_separate.pdf
| seat_overhaul_rearseatlh_doublecab.pdf
| seat_overhaul_rearseatrh_doublecab.pdf
| seat_overhaul_rearseat_accesscab.pdf
| tailgateprotector_rh_replacement.pdf
| tailgate_components.pdf
| tailgate_overhaul.pdf
| windshieldglass_components.pdf
| windshieldglass_replacement.pdf
| wiperwaher_motor_components.pdf
| wiperwaher_motor_replacement.pdf
| wiperwaher_nozzle_inspection.pdf
| wiperwaher_rubber_lh_components.pdf
| wiperwaher_rubber_lh_replacement.pdf
+---In_depth_Electrical
| | abbreviations.pdf
| | connectorlist.pdf
| | connector_partnumbers.pdf
| | currentflowchart.pdf
| | glossary.pdf
| | groundpoints.pdf
| | howtouse.pdf
| | relaylocations.pdf
| | routing_componentlocation.pdf
| | routing_connector_ground_splice.pdf
| | troubleshooting.pdf
| +---circuits
| | abs.pdf
| | abs_trac_vsc_autolsd_dac_hac.pdf
| | accessorymeter.pdf
| | airconditioning.pdf
| | audio_builtin_amp.pdf
| | audio_separate_amp.pdf
| | backuplight.pdf
| | charging.pdf
| | clock.pdf
| | combinationmeter.pdf
| | cruisecontrol_1grfe.pdf
| | cruisecontrol_2trfe.pdf
| | doorlockcontrol.pdf
| | ecmirror.pdf
| | ect_atindicator_1grfe.pdf
| | ect_atindicator_2trfe.pdf
| | enginecontrol_1grfe.pdf
| | enginecontrol_2trfe.pdf
| | engineimmobilizer.pdf
| | foglight.pdf
| | headlight.pdf
| | horn.pdf
| | ignition.pdf
| | illumination.pdf
| | interiorlight.pdf
| | keyreminder.pdf
| | lightautoturnoff.pdf
| | multimode4wd_reardifferentiallock.pdf
| | multiplexcommunicationsys_can.pdf
| | poweroutlet_115v.pdf
| | poweroutlet_12v.pdf
| | powersource.pdf
| | powerwindow.pdf
| | reardifferentiallock_2wd.pdf
| | remotecontrolmirrror.pdf
| | seatbeltwarning.pdf
| | shiftlock.pdf
| | srs.pdf
| | starting.pdf
| | stoplight.pdf
| | taillight.pdf
| | trailertowing.pdf
| | turnsignal_hazard.pdf
| | wiperwasher_wo_intsw.pdf
| | wiperwasher_w_intsw.pdf
| | wireless_doorlockcontrol.pdf
| \---overall
| how_to_use_overall_ewd.pdf
| overall_ewd.pdf
\---More_Audio_and_Electrical
ampmutesignalcircuit.pdf
amppowersourcecircuit.pdf
ampsoundsignalcircuit.pdf
antennacord_components.pdf
antennacord_installation.pdf
antennaholder_components.pdf
antennaholder_installation.pdf
antennapole_components.pdf
avclancircuit.pdf
dtccheck.pdf
frontno1speaker_components.pdf
frontno1speaker_components_regcab.pdf
frontno1speaker_installation.pdf
frontno1speaker_installation_regcab.pdf
frontno2speaker_components.pdf
frontno2speaker_installation.pdf
identificationofnoisesource.pdf
illuminationcircuit.pdf
location.pdf
no1speaker_w_box.pdf
Holy Crap dude that has to be the longest post I have ever seen. I only need the dash disassembly. I have had the rest of my interior out so I know how to do that.
I will send a PM thanks.
dermaestro
That's looking pretty good! How easy is this stuff to use and where did you get it?
lol... i kept scrolling and scrolling :laugh:
yeah how hard is this stuff to apply ..is it as easy as it sounds ??
Sykotic336
That looks awesome yo keep up the good work. I was thinking of laying cf everywhere lol.
That is sick. What type of paint did you use? Make sure to keep us updated on your progress. Black interior is dope
I am using spay vynal and upholstery dye from duplicolor. It says it bonds to plastics as well so I guess we will see. It is just like spray painting. I would guess that the Krylon fusion paint that bonds to plastic, would probably do the same thing. I tried to take a pic of the headliner. The pictures still don't look as good as it does in person. That bright spot is glare off my lid through the slider and is not a mess up. I am very suprised how well this stuff covers. It does not look streaky at all.
Looks awesome man! I'm inventing some stuff for my interior as well..I'll post pics in a month from now. :top:
jockin,just breakdown and order SEM interior paint and be done with it.it's the same stuff unique auto sports uses when they color change the interiors on the exotics.:top:
