I have a Navone N-7785V LOC for sale.
VARIABLE 4-CHANNEL HIGH-QUALITY OEM ADAPTOR
N-7785V $49.90
Order N-7785V .:|
Here |:.
The
N-7785V is a four channel device that features two channels of full range output, plus two channels of low pass out with the same bass boost as the
N-85 and
N-85V. The signal level can be adjusted from a maximum of 9.5 volts rms down to zero volts. This is a great feature for optimizing the S/N of system and a must for competition or demo systems. Turning the knobs clockwise increases the signal level. At the amplifier/speaker we recommend a 1:3 gain structure for most systems. The
N-7785V is a great device to connect an OEM deck into TWO aftermarket amplifiers. The front amps can be fed a full-range signal and the rear channels can be low-pass only.
