SgtBadA
- Apr 21, 2013
- 583
- 33
Ok so a little background on my suspension. I have the XII drop coils and blocks (yes i know i need leaf springs) i also have sway bars bushings that i just greased. I havent had an alignment yet and i know my camber is completely out. Other than that everything else is in specs according the the chart that toyota has. Anyways on with business i have some rubbing/slight grinding noise coming from somewhere when i take corners at low speeds usually when im driving in the parking lot. It seems to only happen when the engine has warmed up and when the clutch is engaged. When i depress the clutch it goes away. Going in a straight line it doesnt make noise or rub only in corners. Any ideas? I dont think its power steering pump cause it doesnt wine and i dont have issues turning the wheel. I was thinking rack and pinion but im not so sure. I dont see any leaks anywhere and all fluids are topped off and clean. Im really stumped on this one guys i could use some help.
P.S. i have 80500 miles on it right now. And i have the stock rims and tires
