SignUp Now!i think fiberfill actually acts as something to make the box act as an even bigger box. It effectively slows down the waves, im pretty sure fiber fill is used in small boxes for "bigger" sound. So yea, if you were to do that in a already too big box then i think it'd really •XR•XR•XR•XR things up.
Ah yes the ol port. I purposely made a small port and box so that the air would really have to force through, so the power handling would stay in tact and the SQ would still be there. It sounds awesome.
In the most simplest way I can describe, this means that you're going to get some sort of delay on the sub hit..05 - What happens if the box is too large?
Typically the low frequency extension of the system improves a little, at the expense of powerhandling. The bass will also sound tighter and "drier", which might not suit your listening tastes. In the case of vented systems, a too-large box may introduce a response peak around the the resonance frequency of the system.
what does the last line mean?
