URD/ S/C=2' Blocks
drewXrunner
Ok. I just bought the 1.75 2' drop. I was wondering if there is going to be a problem with the blocks in the rear, when i install the supercharger. I was thinking that the added horsepower will throw those blocks right from under the truck, but Im not sure. :rock: :laugh:
If, and that is a big if, you could make your truck to produce enough torque and get enough traction to rip the blocks out, you would first either snap a u-joint or twist the drive shaft. You have no worries about putting the blocks in.
You may want to consider the URD traction bar. You get wheelhop stock, with more power and blocks you will get more wheelhop.
2" blocks and URD at 9psi didnt have too many issues. 4" blocks it really didnt get along with though.
That will be a heck of a torque! :biggrin:
The U-bolts are very tough. You would need an incredible amount of torque to throw the blocks from the rear of your truck. Trust Jon he had the fastest truck on here with no problems
