URD short shifter installed. help and questions
URD S.S.
Sorry for all the questions but i need help badly.
I think i messed up on the SS installation.
Please help me.
1. Is there suppose to be a gap between the spacer and the shifter assembly due to the dowel pins?
2. What happens if i damaged the bushing? (I pried it off with a small flat head screwdriver and there are some "dents" on the inside and outside and its not completely round due to them.)
3. Do you sell or know where to buy bushings for a 2008 Tacoma 4.0L V6?
4. Are the throws suppose to be 100% smooth right after the install or is it gonna get better over time?
5. While shifting, are there suppose to be "clunks" between the shifts? Is this problem caused by the damaged bushing?
6. Is it possible to remove the allen screws that are thread locked and staked? If so, how?
Please please please help me!!! I feel like i messed everything up.
DustyXRunner
the pins should have come out of the top of the tranny and gone on top of the spacer i believe. if i am remembering corectly. and the bushing being messed up may cause it to feel a bit chunky. i did notice that mine does feel a little more solid than the stock throw, but not chunky.
DoubleD
Please help me.
Nope the pins should fit in the factory holes in the case
I would think that as long as there are not major issues with the ball you should be ok.
Toyota Dealer
Mine never was smooth no matter what I did and what fluid i used and I tried many
Again not smooth transmission
I could not get mine off. Had to drill it but I over tightened them i think. I had to drill them out but I would say dont over tighten them and use removable lock tight your fine. if you cant get them out then you have to drill them out
Good luck dude! Call Gadget at URD he will give you all the info you need:top:
URD S.S.
thats exactly what im gonna do 2morrow.
Do you guys have any ideas where to buy bushings?
DustyXRunner
probably the dealer. you might be able to try a shucks or carquest or something. they might have generic replacements. if you take the bushing out they could probably match it up. good luck bro.
URD S.S.
thanks dude but i live in hawaii and i have never heard of shucks or carquest.
what about napa or checkers?
any other suggestions?
DustyXRunner
lol. napa and checkers are the same type of parts store. those would do fine. i always assume people know exactly what im talking about. lol. my bad. :bird:
URD S.S.
sorry about that :frown: im not a wrench head lol
do you think the dealer stocks them???
URD S.S.
alright imma call all those places 2morrow
ill update you guys
Thanks for all the help DustyXRunner your awesome
Coupe
Please help me.
No.
The dowels are a close fit. if you make them "out of round" they will probably cause the gap in question 1.
Dealer.
I bet you are shifting the truck at rest. When it is moving and oil is circulating it will be a little smoother. I also recommend a good synthetic oil. It will make this a lot smoother.
Yes, but you might damage the screws. be sure to have a spare set when you do this. I have used an allen wrench and have removed them in the past.
Replace the dowels pins and you should be good to go. It will also work with the dowel pins removed. If you remove the dowels, be sure you add silicone in this area.
URD S.S.
The dowels wouldn't fit in the spacer provided by URD. The holes in the spacer were too small. What should i do? If i remove the dowels completely do i need to add silicone in the enlarged holes?
It was a pleasure speaking to you on the Tech Support line.
Page 13 step 6 describes the fitment of the dowel pins and the spacer plate.
The dowel pins, both of them, should come out with the
shifter assembly. Occasionally, one or both of them will
stick in the transmission. If this happens you will need to
pull the dowel pin(s) out of the transmission with a needle
nose pliers and insert it into the enlarged holes in the URD
spacer plate.
When the spacer plate is installed on the transmission, both
of the enlarged holes should be facing upward with one of
them in the front right position. This will allow the dowel pins
to line up with the shifter assembly when it is installed onto
the spacer plate.
URD S.S.
thanks gadget
Im just going to remove both the dowel pins and replace the damaged bushing.
Hopefully that will fix everything.
Ill update you guys.
I just came back from Toyota and ordered a bushing. They said it will come in a couple of days. Hopefully I get it by saturday so i can do the re-installation. I'll let you guys know what happens after the dowel pins are removed and the bushing is replaced. Im hoping it will feel a lot better than how it feels right now.
UPDATE!!!
I drove my truck to work 2day and i noticed a couple things about the short shifter.
The "notchiness" or the "clunks" seemed to decrease. I couldn't feel it as much as i did the first time.
Also, its a little harder to shift than the stock shifter. (all gears not just reverse)
Are these normal for the short shifter?
DustyXRunner
UPDATE!!!
ya i would say this is normal. mine was a little more solid when i first put it in. you will get used to it. i like being able the FEEL the engagement in every gear. gadget im sure could tell you more.
BadAzzXrunR
Please help me.
Sorry I'm late at posting. I missed this thread somehow. Heres a thread I started months ago. Probably another known failure item that Toyota will not own up to: http://www.xr-underground.com/vb3/showthread.php?t=31360&highlight=bushing
URD S.S.
Alright Thanks Guys!
I'll let you know how the shifting feels after i get the bushing replaced and the dowel pins removed.
Hopefully it shift a lot smoother and less hard. Other than that I LOVE THE SHORTER THROWS!!!
Thanks again!
BadAzzXrunR
Also...try replacing your tranny fluid. Putting Amsoil synthetic made a world of differnce for me :top:
