Urgent help!
808X
How do I take the grill off??? Im having trouble taking off those black plastic screws without breaking them. How do I take these off??? I cant even find the other screws I need to take off from the headlights I can find the top two...
Take a flat head screwdriver and pry up the round button on the top. Pull the button up and the clip will slide out.
808X
I will try that but I cant get to the screws with a flathead screwdriver...the clips are horizontal
To get the grill out there are two metal phillips screws and then two plastic pop-up clips. The pop clips come out by popping up the center. You have to pry under that round head enough so you can fit your finger nail under and pull that center up. Once the center is popped up you should be able to sqeeze the bottom and feed the clip out.
The headlights have two screws up top and a third under the turn signal underneath the front bumper cover. There is also a 10mm bolt that you have to get to from under the truck.
808X
The two pop up clips those are kind of attached to the headlights? Is that what im trying to take off? Im trying to do this as we speak thanks man
They are right next to the headlights. They actually are attached to the piece of plastic body that goes under the headlight.
808X
I got the grill off thanks
now the other screws i got the top 2 but the one underneath is it near the outside of the truck? A black screw? I cant find the one on the top yet...Im trying though its frustrating
thanks for your help
I will tell you this - if you're doing the BHLM - when you go to remove the body molding directly under the headlights you will have to break the outside clips. After unhooking everything else - just give it a good pull toward the center of the bumper and SNAP!
The screw that is difficult to get to (headlight) you have to get to from under the truck. It is on the very outside of the truck/bumper on the inside. You can't see it - you just have to feel for it.
See here:
That circle ISN'T the screw. It's on the other side of where the circle is.
808X
See here:
Ok I found the screw but I cant get it loose? its not the black one right???
808X
Ok I FINALLY GOT THE HEADLIGHTS OFF but now what parts go in the over??? I took off all the connections to the headlight, the 3 hex screws and is that all i take off??? Please help
Take as much as you can that you can remove off the headlights then put a headlight at a time in the oven. Be prepared to do some prying and you might need to put each headlight in more than once to get them properly separated. I know I did.
808X
what about the huge plastic piece? the one where all the screws from the truck mountings. Do I try and pry that off now? or do I leave that on? I took off two of the bulbs I cant take off the turn signal bulb is that ok? Should i put it in the oven?
You want to take out all the bulbs. All the bulbs should twist out. If you want to hit me up on aim my SN is nbird87. I will try to help out the best I can over AIM:top:
Now thats help... thats what makes this site so great :top:
I didn't know that when I did mine the first time. I thought I broke the damn thing:laugh: I was like aww crap what snapped:biggrin:
That's why we are here, to share and help:top::driver:
808X
hey thanks for all the help guys. I cant put the headlight back together without chipping the paint. The headlight doesnt quite fit should I reheat the plastic backing and the clear lens ? Will that make it go together easier?
It will fit in there without any heating, trust me. It just takes some gentle persuasion. Once you put the headlights together don't forget to add silicone around the edges. With all this rain we've been having the last thing you want is foggy black headlights!
