- Dec 10, 2006
- 9,069
- 44
Source: www.toyotanation.com
I just took the hood scoop insert off of the hood to see how it was made and see if I could do anything with it. To take it off you just unscrew the five 10mm nuts and one phillips screw. You might want to use a magnetic driver when taking out the phillips screw, so that the screw doesn't fall down into the frame of the hood. The metal screen and the plastic piece behind it are sandwiched together and held to the fiberglass by 3 rivets. You can drill out these rivets and then you would be able to separate all the pieces and modify them how you want. My truck kind of has a straight black theme going on so I decided not to modify it (for now). But if I had a model with the chrome grill and stuff, I would probably take the screen out and paint it chrome to match. I think that would look pretty cool. Or it would be cool if you have a bright colored truck and painted the screen the same color as your truck. Or you could leave the screen black, but paint the plastic piece behind it. Or if you're good with a drill or a Dremmel tool you could cut out some of the plastic and make air actually flow through the scoop.
It would be pretty cool if some company made a billet aluminum screen to match a billet aluminum grill.
If my truck wasn't all black I would certainly do a little modding to the scoop. Just thought you guys might want to know what can be done with the scoop.
