- Jan 14, 2007
- 13,448
- 4
Nice little write up, clean install bro :top:
SignUp Now!Sorry posted so many times. Pretty hard way to do this mod but also proud.LOLNice little write up, clean install bro :top:
So I finally got around to doing this mod - wish id done it sooner :biggrin:......Pretty hard way to do this mod but also proud.LOL
Probably doesnt matter to you by now but...Man I couldn't take apart the fuse box :motz:
If I remember correctly there are 4 clips that hold the fuse panel into the outer shell/box. 1 on the engine side, 1 on the firewall side and 2 on the fender side.
I loosened them in that order and with a little pressure and wiggling I got the fuse panel out in a few minutes.
:beer:
All you are doing is tapping the red/blk wire into the green wire and capping the other end of the red/blk wire.:top:
What side of the green wire though?? After you cut the green wire (from underneath the fuse panel) There is the end the travels to the white clip, and the end that leads down into the engine bay.... So which end do you connect the red/blk wire to? Or do you just slice INTO the green wire?
