Differing Truck Heights?
Can anyone explain this to me?
Extended Cab & 4WD Regular: 69.9 in (1,775 mm)
Double Cab: 70.1 in (1,781 mm)
Regular Cab 2WD: 65.7 in (1,669 mm)
2005-06 X-Runner: 65.2 in (1,656 mm)
2007-Present X-Runner: 72.2 in (1,834 mm)
I know the body kit will make the early X's lower then a 2wd Tacoma but I'm shocked to see it say 2007-11 being as heigh as it states. What gives?
Yea i have no idea! According to wikipedia where those stats are from, the 2007+ Tacos are exactly 7 inches higher??
hottacoX
There is your problem.... Never ever trust wiki!!!
lj973gm
Maybe they fixed the crappy rear leafs that come on the truck. Likely now since the 2012 truck are coming with half 3 or 4 leafs it is odd. Not consistant from the reviews online.
There is a TSB for gods sake fix the problem it is a truck not station wagon.
When you say height are you referring to the distance from the ground to the top of the cab? If so I cant believe that an 06 is 7 inches lower overall than on 07. Something about that doesnt seem right.
+1 on that.
Is that wheel base lengths?
sweetwilliebrownjr
My truck is 48.2 inches tall, and while that may be an arbitrary, comPletely made up #, it sounds good to me. Maybe I should write wikipedia articles.
hottacoX
Thank you!!!! Somebody who finally gets my point, anyone and anybody can post on wikipedia!!! Think of how many tards exist in this world and anyone who has enough sense to log into the wiki site can change the information posted on it!!! Bottom line NEVER TRUST ANY INFO ON WIKIPEDIA!!!
When I was in university if you referenced wikipedia your paper instantly got a fail!!
