SignUp Now!Where can i find bigger rodors!? I cant afford the trd brake kit right now so im looking into just rodors right now. What will work on the x-runners that is bigger than stock and slotted or drilled.
Fixed thread title for ya:top:Rotors! .... Sorry
I believe Tundra racing still has rotor bbk on sale for 1300, don't waste your money on just rotors. Save up for the kit
U cant just add bigger ROTORS to ur brakes, there's no room! U would have to get one of the few BBK's that are made for our trucks
Have you all tried changing your brake pads out? That alone along with some better brake fluid is more than most will need even on track days. Just saying, a BBk is often not the end-all solution for what you need, and most of the time it's excess.
Butters drag strip and road coarse are two totally different things I'm sure u know. If ur getting any fade whatsoever at the drag strip no matter how many passes then u will be doomed at a road course where there's no time for the brakes to cool in between aggressive stopping, at the strip you've got the whole way back from the going thru the traps till u line up again and then go thru the traps again for the brakes to cool......that's more then enough time to cool down between passes.
