Bulldogger
- Oct 30, 2011
- 616
They will be pretty close as long as the boost isn't real high. TRD has a smaller water to air intercooler (where URD is just air but larger) but back to back dynos on stock trucks with TRD showed no hp/tq loss, so I would say it's fine for at least 6 lbs. You can't see downstream IAT's but you might be able to monitor engine timing. When is starts being pulled IAT's are climbing. If heat is a concern with the TRD unit spray meth.Does anyone measure intake temp? I would be curious to see exactly how much cooler turbos/URD units are...
After all, pressurized air is pressurized air - only difference can be temp.
