Bump Steer Kit Ideas...
I swear I saw someone recently post about using heim joints on FB....
autobodyX
I made myself a kit several years ago and have updated the design a few times and yes it’s on Facebook in the xrunner group. Nobody wants to pay for a kit they want to find and buy the needed parts themselves. The tricky part was making a sleeve. The more recent design uses a replacement inner tie rod and a off the shelf everything, nothing custom.
Lynxshd
No nothing I have been waiting for this kit since 2007, there are less of us x-runner hardcore owners everyday I'll continue waiting for this bump steer kit ever comes I'm in LA Cali if any other xrunner member wants to meet up hit me up
Bummer, I am in norCal so meet ups are non existent up here.
Lynxshd
The part that I freaked out over is the re drilling the spindles to match the angle of the tie rod end
autobodyX
The GM style adapter stud has the same taper and is a direct fit. You may have used the ford style.
Lynxshd
That is great news I, never moved forward because of that, and just last night ordered this ->
GM tie-rod adapter.
as the truck atm is influenced by the road too much and, the roads around here are under massive construction and have been for years.
I am thinking of doing the lower control arm bushings while I am at it, so I only need to get 1 alignment.
Lynxshd
Parts ordered. for a bump steer kit​
Adjustable GM Tie-Rod Adapter Stud to Heim
Part # 91636055-GM
Price: $14.99
Qty: 2
Steel Cone Spacers for Rod Ends, 5/8 Inch
Part # 5464110
Price: $10.99
Qty: 1
Seals-It WS6250 Heim Joint Rod End Seals, 5/8 Inch Hole, Set/6Part # 91001504
Price: $12.99
Qty: 1
RockAuto Tie Rod End
Part# MOOG EV319
Price $20.79
QTY: 2
McGillmotorsports.com - M16 x 1.5mm Right Hand Female (XFRM16x1.5) Ultra High Performance Rod End
Part # XFRM16x1.5mm
Price: £12.05
QTY: 2
I went with the moog ev319 because it has more thread on it than the ev320, and I have seen in posts where that mattered for some.
Lynxshd
I was checking out the facebook group for people that have installed this and noticed that the new tie-rod adapters don't use a castle nut to allow a split pin, should I drill the nut and adapter to put one it? Surely that is not safe with out.
autobodyX
The nut is a nylock, I’m not sure I spelled that correctly, style retainer that is an industry standard now. The fastener locks itself but is not reusable like a castle nut.
A drop of lock tite on the inner tie rod to steering rack shaft is a recommended.
Some people don’t like or understand that the taper on the adapter stud does all the work, the gap under the spindle between the end of the taper and the shoulder of the stud is not a issue so do not over tighten the stud to close the gap. The taper bottoms out not the stud. It’s not a bolt.
Lynxshd
That is great advise thanks so much for that, I will just torque it down to spec, to not over tighten it.
Lynxshd
after ordering these parts and getting them all together and ready to go on the truck, there seems to be to much play, and the taper on the adapter is close but not perfect. I have reached out to a company that makes specific bump steer kits for drift cars. I have an appointment tomorrow to have the taper fitted and the kit assembled specifically for the xrunner, these are high quality kits that last for a very long time. if anyone is still interested I will post a link to the kit once it is all measured up.
autobodyX
Please explain close but not perfect. The only complaint anyone has ever had was the stud doesn’t completely bottom out in the steering arm. It’s not intended too.
Lynxshd
From what I have been told the taper/angle of the steering knuckle is not a perfect match for the taper/angle of the pinto or the GM adapters most people end up drilling out the knuckle to make it match perfectly. I just had the adapters machined up to be a perfect match, that way I don't have to worry about any weird wear or the knuckle and adapter coming loose after they seat themselves.
