Brake dust solution
Older Guy
I fixed the shitty brake situation by installing TRD pads....
However, the resulting in brake dust all over my wheels is a mess.
I saw a video online about Armor All wheel protector...
I bought a can and sprayed my wheels after a car wash....
It really works.....no more brake dust.....
I have been looking for that stuff. Where did you find it?
I'm gonna have to disagree. I used this stuff when it first came out. Worked for about a week, then it wore off. I don't agree with buying this stuff constantly just have wheel dust not stick. I'd rather just wash my truck and save the money.
Tunedx
I agree this shit definetly works, on my third can.
Whitebeauty
Ive been having some brake dusting issues too, but after talking with Rotora it seems like i was sent the wrong calipers....It has to do with something about rear trailing piston and forward leading piston.. apparently the rotora kits have, on 6 piston caliper, have 3 different size pistons. the largest one is the last to grab. Well in the kit i got its the first to grab...idk but i have another set of correct calipers coming soon. So we"ll see..
Whitebeauty
If u look close the bottom piston is the larger one of the 2....The rotation of the rotor is counterclockwise
Red_Hott
My suggestions is run the EBC green stuff pads...since i switched to them brake dust is no longer an issue
micpun
its the only way that i can keep my white rims, white.
I thought about changing to a less messy pad but the trade off is less stopping power. No reason to buy a BBK to get less stopping power.
Red_Hott
im not sure white beauty it would be something you would have to look into....and i have no brake fade at all with them and with drilled and slotted rotors i cant ask for a much better setup out of a stock 1piston caliper
