SignUp Now!Does anyone know of our engines are interference or Non-interference engines?
You do not have the timing marks on the intake cams in the proper position. Not even close.
Look like the driver's side exhaust cam is way out of time.
Line up the intake cams to the bearing caps and the crank pulley to Zero. Once you have done that the exhaust cams should be in the proper position.
I think you are more focused on the paint marks on the little chains instead of lining up the engine properly.
I will bet you have the drivers side exhaust cam two teeth off.
When I did mine I just lined up the timing marks and put a little dab of paint on the chain link over the mark on the gear. I don't think I even turned the crank 2 revs. Did I just get lucky? Why does no one else use this method?
Can i get definitive Gadget confirmation that the driver's side is behind by one tooth? I really don't want to do this again lol :rockon::hmmmm2:
and to be absolute, the dotted tooth should go under this link, right?
