How is the clarity on that film after the install? Is the film noticeable? When you installed did you use water like you would on a tint or did you guys do a dry install?
Any of your tips would be great:adore:
Clarity is excellent. I went with Venture Shield over 3M 'cause of the surface texture is smoother, and its more user friendly (flexibility & elasticity). A lot of peeps didn't even know that I have the clear bra on 'til I point 'em out.:biggrin:
Yeah, I put them on wet. That way you can adjust them to the right position, it also help you chase out the air bubble. As for the solution, its not just water. 2/3 water, 1/3 isopropyl alcohol ($.99 store), and a little bit of dish soap (Dawn/Palmolive). Make sure the surface is very clean. Work in a area with no wind/breeze. Use the solution generously, on the vehicle & clear bra. Spray some on your fingers to help prevent finger print on adhesive. Position the vinyl on the vehicle, check for fitment. Some stretching is necessary to line up the edges. Use short stroke to help prevent leaving air bubble behind. Most importantly, be patient and take your time.
Let me know if you got anymore question.:top:
