Clutch Sqeak Help!
TacoDude
I know alot of people are having problems with there clutch squeaking when they depress there clutch. But my problem is when i compress and depress my clutch there is a load sueaking noise outside of my truck. i've had the problem with the squeaking in the cab but now i can hear it coming from the outside. does anybody no the problem for this????????:hmmmm2:
justin13703
[ame]http://www.youtube.com/watch?v=-QWRbepIGdE[/ame]
Does it sound like this? This is a vid of my truck. Mines done that for years. I tried spraying it with white lithium grease and that didn't do anything. I have a stage 3 clutch lightweight steel flywheel and the tsk. I don't worry about it cause it doesn't do it when the engine is running.
TacoDude
it kind of makes that noise. but it squeaks like that when the engine is on or off...
TommyXrunner
is your clutch master cylinder leaking? my old taco started getting a squeaky clutch and soon after my clutch master cylinder was leaking inside under the clutch pedal
hottacoX
I have a similar problem, squeeks on the last say 15% as you depress the clutch, weather the engine is running or not it's there so not the tob. While not a mechanic I was told it's a plate that engages/disengages the clutch that needs to be lubed.....:dontknow:
TacoDude
im not sure. i would have to check on that.
hottacoX
Mine is not..... Brake fluid is spot on...
justin13703
Yeah nothing is leaking on mine either. I was told to remove the inspection plate and hit the input shaft with some white lithium grease and I did but that made no difference.
TommyXrunner
if you can't fix the squeaky clutch just crank the tunes up or get a really loud exhaust......squeak will disappear instantly!
