uh60rotorhead
- Jan 17, 2007
- 820
I let it warm up to at least the bottom line every time.
SignUp Now!When you first start any car up its in open loop and the afr is rich then leans out to 14.7. It doesn't stay in open loop very long though.
Being an FI motor makes it extremely important to let it warm up.
Do you mean forced inducted engine or fuel injected? If fuel injected, then letting the car warm up is redundant unless of course you are in an extreme cold environment. Starting the car and waiting for it to warm up came out of the carbureted days. Carburetors on cars worked better when they were warm. With fuel injection the car automatically adjusts the fuel and air so that the car will run smoothly regardless of temperature.
If it's 40 degrees or higher outside there's no reason to allow a modern fuel injected engine to warm up by idling. You are just burning gas. Drive easy until in normal operating temps then have at it. However, you do not want to run an engine hard while cold. If you do this you can do severe damage to the engine regardless if it's a Toyota or Honda. Like DS said engine components expand and shrink based on temperature. When the engine is cold the oil doesn't flow as well and the engine components and seals are not expanded. My neighbor across the street killed their Avalon by constantly running the engine at high RPM while it was cold. Eventually blue smoke would shoot out when the car started and finally it began knocking like a deisel before dying.
So since I have always let my truck warm up, there's a chance I have some gnarly carbon build up?
If I do, is it reversable? I use only Shell gas and have always used Royal Purple and K&N filters since day 1...
