- Dec 10, 2006
- 9,069
- 44
(writing this from my iPad so it will be short)
2 months ago had passenger side cat go bad - replaced under warranty by Toyota. Afterward started noticing lots of soot around exhaust, never noticed that before. 2 weeks ago started noticing engine knock, check oil level - almost empty. Got oil and did immediate oil change. Probably got around 1 quart out of the engine when draining. Sounded a little better the next day but after a couple days the engine knock got much worse. Noticed no oil leaks except small amount around filter.
I was leaving for vacation so left the truck with Toyota to have them assess and diagnose while I was gone. Just talked to them and they said they removed the S/C belt to ensure the sound wasn't coming from the S/C. Simple assessment, the tech is thinking its a rod bearing on cylinder 6. Need to pull the engine to replace.
I asked if they had done a compressin check on the cylinders. He said no. So I'm having him change all of the plugs (time to do it anyway) and compression check each cylinder while doing it. I also asked if they had any ideas where the 3+ quarts of oil went... He said no. But that COULD have caused the first cat to go bad. I told him that they must find the cause for the oil burning.
Anything else I should have them look for? Any ideas what could be going on? This is my first major issue with this truck and I'm looking at a $2000 repair here (out of warranty). :frown: Good news to get while on an expensive vacation we planned 7 months ago.
Only mods are TRD CAI and MAPECU2 on engine.
