Engine oil cooler
blackx-runner
"White Flash"
How about a universal oil cooler setup, preferably with thermostat. I want an oil cooler but don't want to throw down the money for the oem setup.
XrunnIT
When I was with gtmoy, I thought he had a custom oil cooler... :hmmmm2:
ntinhri
I'd be in on this.. I think a vendor should be able to put a deal together for 150-175..
gtmoy
I'll get pictures when I take off my bumper today or tomorrow. I have a thermostat oil cooler with a B&M oil cooler
VIPDreamin
"Mr. Incredible"
not sure what to look for.. send me the part numbers your ordered..
I swear you are slow or something in that NOVA water...for the 10th time..my oil cooler is OEM Toyota!:biggrin:
My68ur8trd
Ill build mine again tonight and send it to you:smile:
is the same package as that ebay special I showed in the other thread, but with known quality components
Justin
T0LLPHR33
"Catwoman"
I want 1 too...:biggrin: pm me the part # and components list please Justin...
5H4D0WD347H
Ive got a full OEM Oil cooler assembly, the one tube has a dent in it, it can be fixed or used as is.
This setup costs big bucks brand new, im taking offers on it.
My68ur8trd
match the 175 Im gonna spend on the setup from Summit and I will take it. :smile:
Justin
gtmoy
Bmm-70273 oil cooler $62.88
hda-112 oil cooler hose $25.95
hda-205 adapter kit $29.95
prm-15156 fittings brass (2) 1/2 x 1/2 $3.95
blackx-runner
"White Flash"
Go to summitt .com goodness
I wanted to do it the easy way and also support the vendors here.
But I did order my Greddy oil cooler adapter last night. now i need the cooler and lines and i will be set :top:
micpun
so tell me why the oem one cost so much? :hmmmm2:
blackx-runner
"White Flash"
because it is toyota OEM :rolleyez:
I would really like one, but for the price I think a summit special will work just fine for my application.
ntinhri
So anyone have the package they put together???? I need to order asap
VaBchXRunner
"The Bargain Baron"
It's the mountain water..... geesh, easy on the slooooowww kid
My68ur8trd
This is what I was working with
Part # Item Price Qty Line Total Delete
DER-51008
Fluid Cooler, Transmission, Plate-Type, Aluminum, Black, 10-Row, -8 AN, 4.563 in. x 13 in. x 2 in., Each
$76.95
$76.95
HDA-205
Thermostatic Adapter Kit w/ 3/4"-16 Thread
$29.95
SUM-220847B
Fitting, Adapter, Straight, Male -8 AN to Male 1/2 in. NPT, Aluminum, Black Hard Anodized, Each
$4.75
SUM-220890B
Fitting, Hose End, Straight, -8 AN Hose to Female -8 AN, Aluminum, Black Anodized, Each
$6.95
SUM-230806
Hose, Braided Stainless Steel, -8 AN, 6 ft. Length, Each
$29.95
Total - 174.15
The only thing that I dont like is that filter adapter doesnt have ports for gauges.
