SignUp Now!Have you made any changes to it? How did the afr's look?
Numbers seem kind of low, esp based on the mods listed.
A bone stock XR will read up to 210 at the wheels SAE corrected. STD always reads higher.
Your torque drop off is very bad. Something looks wrong. Do you have the APR t-stat and timing gears installed?? What tune are you running?
Don't take this the wrong way brutha but if I were you I would work on my track skills a little more before running out and droppin 4k on a blower to make up for those 16's and 17's you were runnin. Yes...I saw the vids & slips. I know how you feel and what you're thinkin but money and mods is not a replacement for practice and driving skills, ask Nick Hogan.
If you just boosted your truck now, you may find yourself even more disappointed than you were then, when you end up still in the 15's. I've run within half a second of a guy with a boosted xr and I'm N/A. Don't let that guy be you. Hit the track more often, learn your truck and how it needs to be launched and shifted and just figure out what works best for you. Crawl before you walk my friend....
If TLC = maintaining her, I can check that off. Everything service wise has been done by the book. :top:How about some TLC? I would definitely do some datalogs as well.
Xrunnit is right. Power is low. I wouldn't say that it is due to having well over 100k on the odo. Now, here is the question. Have you ever changed your stock fuel filter or upgraded your pump to the Walbro 255lph kit? If you haven't, tour fuel system is fighting a clogged filter as well as an already weak small pump.
If you haven't done the upgrade to a larger pump, say the kit from URD, you need to. I bet you would pick up a good deal of power. Then, time to start looking into other points.
If we were able to see the AFR I bet that we would be able to see what was going on in the higher rpms.
just because you can get down the track is no excess not to get the blower!! some people dont care too much for the track and just want some extra pep.. the blower is the way to go if ya want to up the power...
track night was not my night when we went... i was popping off 14.5's all night.. it was pretty frustrating hell i could not get over 100 mph.. i ve hit high 13's and trapped at 105 plenty of times..
its never not time to get a blower :smile:
how is power fab with tuning?? i got a maf cal.... but it seems pretty one off to a shop since there is not many of these running around..
Powerfab is A +, with me :blurock:. They're nice to nerds.
Any reason not to install the JBA & wideband @ this point?
that should give me more info, right.
Thanks for all the input XRU fam,
needed it.
