FS: OEM oil cooler
I have a complete OEM oil cooler for sale minus hose clamps. Reason for sale, when i ordered my URD MK3 kit i decided to order an oil cooler at the same time. But once i received the cooler i noticed my Tacoma never came with auxiliary ports for the upper and lower hoses :stupid:. So here i sit with a useless oil cooler thats never been install and needs a new home. What you see in the pic is what you get. Asking $500 shipped. PM if you have any questions.
Items In Picture
-Oil cooler assembly - Part#:15710-31010
-Upper hose - Part#:15778-31010
-lower hose - Part#:15777-31010
-Center bolt w/ washer - Part#:15695-22010
If you want to use it you can just order a new thermostat/water housing.... It's like $50 I believe....
I would but i'm currently using this and i kinda need it for my oil temp and pressure senders... if i wasn't all ready running what i have i would.
Stack them....
Get the greddy plate and you can stack them.... Slywitty is running that set up and I will be soon !
If i can't get rid of it i will, but i was hoping to use the Greddy sandwich plate and piece together an oil cooler setup from selling this unit. How hard is it to change out the water inlet? And $50 new or used?
blackx-runner
"White Flash"
Just to clarify any X-runners wanting this will need to get the new front water manifold with the extra inlet/outlet for the cooler. None of our vehicles had that from the factory. Changing it is fairly simple. A few bolts, pull off the old one and replace with the new one.
Still they are great oil coolers.
Slywhitty
"Midget Magnet"
Yup double stack here! Lol works great!!
Also When I swapped my motor the new one had the ports for oil cooler. So I can't help ya with prices but can say its worth it though.
I have this arrangment also. I stacked mine.
Does anyone have or know part numbers for this water inlet that will accept the OEM oil cooler???
butters607
Little off topic but I made a long write up on a custom oil cooler system and it works great you will get better temps than you ever thought of with the kit I put together than the factory sandwich style.
KETCHUP
GL on the sale. I am running this OEM cooler on my truck when I rebuilt my last motor. Well worth the buy if your boosted IMO. Always good to cool that oil down!!
GrumpyOldMan
BUMP FOR A DEAL:
Just need to add the following:
P/N 16323-0P020 T-stat housing (About $100)
Good idea to replace these as well..
P/N 16326-31010 thermostat o-ring
P/N 96761-35031 upper tube oring
P/N 16325-31010 lower oring
Dave
If you want I can order the parts through my local dealer.
The counter guy is a member here and gives me pretty good deals.
GrumpyOldMan
Wished I'd have known that G....
I ordered it all from an online place out of Ohio....hope the shipping doesn't take TOO long!
picaCulo
Dammit sure wish i had the money ..................BUMP good luck with sale!
X-roller
check your pm's sir. I can't believe I didn't see this.
