micpun
- Apr 16, 2007
- 1,315
Hey guys I keep getting a P0136 code on my OBD II with the X-1. When I looked it up its said
"Essentially the same as P0137, a P0136 code refers to the second Bank 1. The O2 oxygen sensor produces a voltage between .1 mV and .9 mV. The ECM monitors O2 sensor voltage and determines if exhaust is lean or rich. O2 sensor voltage is high when exhaust is rich and low when exhaust is lean. The ECM monitors this voltage and increases or decreases
pulsewidth according to fuel/air ratio. If the ECM detects low HO2Sensor voltage for an extended period, it will set P0136 Conditions required to set: HO2 sensor voltage is low for longer than 2 minutes (minutes depend on model of vehicle. Could be up to 4 minutes)" on
I thought the x-1 is supposed to stop the CEL for this?
