bought my LS halo projectors a few years back and the drivers side halo is out, any ideas?
dmbfan73 Active Member Joined Sep 23, 2008 Messages 1,156 Reaction score 0 Dec 6, 2012 #1 bought my LS halo projectors a few years back and the drivers side halo is out, any ideas?
BSP06XRU Old Member Joined May 14, 2007 Messages 13,011 Reaction score 102 Dec 6, 2012 #2 Did you wash your truck recently? If yes, check for water in the connectors. Even if you don't see any, blast them with compressed air. That's what happened to mine and that did the trick! Good luck! :top:
dmbfan73 Active Member Joined Sep 23, 2008 Messages 1,156 Reaction score 0 Dec 6, 2012 #3 thanks, i'll give that a try.
BSP06XRU Old Member Joined May 14, 2007 Messages 13,011 Reaction score 102 Dec 6, 2012 #4 FYI: The water in mine were in the 4-Pin connectors (female side).
captainkimhawk Member Joined Oct 7, 2012 Messages 66 Reaction score 5 Dec 7, 2012 #5 same here just check for water
roy365 New Member Joined Jul 21, 2008 Messages 480 Reaction score 1 Dec 7, 2012 #6 Are these the same connectors most headlights use, and are supposed to be "weather & waterproof"? Or are they the ones you manually place the pins the rear?
