- Jan 13, 2007
- 10,932
- 173
If you have ordered a URD Stage 2 Clutch recently and have not installed it,,,
Please check to see if the alignment tool will fit into the hub splines of the clutch before you start your install.
We had a few stage 2 clutches that were assembled with the wrong hub spline in them. We have accounted for all of them except for ONE.
There is a chance that it got out to a customer. We have reached out to all the customers that have ordered a URD Stage 2 Clutch recently and cannot locate the missing clutch disc.
So, just to be safe and before you drop your trans, make sure you have the correct hub spline.
If you have the missing clutch please contact URD ASAP so we can swap that out for you.
