X-Caliber
- May 21, 2008
- 627
I have a real bad 5th gear grind at higher rpm's, i kinda gotta feather it in. 6th gear got stuck on me tonight, and I wasn't able to disengage it. I let off the clutch and it stalled out, so I cut it off, turned it back on, and it was still stuck. I was in the middle of nowhere so I kinda muscled it out of gear, and got it driving again (THANKFULLY.)
No more problems untill I got to my destination, but I had to move my truck earlier for a friend to get out and I was just testing the gears so I eased it down into 6th when the truck was idling when the clutch was in and it got jammed again, and took alot of muscle to get it out of gear, upon which it drove like before.
Sorry for the long read, but I'm at a dead end here, i'm not real experienced on the transmission's on the X.
After doing some thread digging, i've heard either:
Bleed the clutch out (Which I have no idea where the bleeder is, never done it)
Bad syncro's (Which I have no idea where I can get that fixed/tested/replaced)
Bad slave cylinder? (I think this is the right part that someone said. One of those cylinders)
Only mods on the transmission is the URD S/S, but it doesn't feel like its causing the problem. I'm not driving my truck any more this week untill monday, upon which I have to drive it back to college.
I'm sorry for the life story here, but I'm trying to give as much info I can.
Truck is an 05', less than 100k on the odo, and I dont think the tranny fluid has been changed, unless it was done sometime during a stop for scheduled maitenence.
Thanks guys, this forum really helps me out alot, and I appreciate any input.
