joshxrmora
- Mar 9, 2010
- 80
- 5
So i waited two extra months to change my oil. Not on purpose of course but with the holidays and life getting in the way my 7k mark was overshot and i wanted to be sure that i got a good flush. So as i was buying Oil i went ahead and bought two extra qts. when i had flushed all the old oil out and replaced the oil filter i stuck the drain bolt back in and filled the truck with just two qts. of brand new oil. after this i started the engine and let the truck idle for about 2-3 minutes. i wanted to do this to see how dirty the brand new oil would come out. but i didnt want to waste a whole 4.5 qts either. anyway after this i flushed the 2 qts (which by the way looked far from new after only 3 minutes at idle) and finsihed up by putting the 4.5 qts back in and went to check the oil lvl. when i turned the truck on to let the oil cycle though the engine my oil filter wrench slid off the engine cover and into the fan gaurd. the result was a flying oil filter wrench, a chunck of plastic out of the fan gaurd, and 1 of the 7 blades on the stock pully fan had been broken almost entirely off.
Heres my ?.
Will one blade missing from the plastic fan cause noticable imbalance on my engine?
Im asking because now when my truck is at idle i can feel a slight pulsating vibration. or a shake that isn't constant but comes and goes almost like if the engine were missing a spark.
I also want to know if i may have (fu**ed up) by starting the engine with only 2 qts? could this cause a issue that would result in a slight shake in my engine.
thanks,
Heres my ?.
thanks,
