SignUp Now!I knew we kept you around for a reason:laugh:.....Good freaking job!!!!
they are GTO seats... how does that make them URD?
Sure. The issue is the airbag system.
If you want to shut it down, no problem putting any seat in the truck. If you want to keep it working things get complicated.
that's very true...:hmmmm2: I wonder if that would work with the electronic adjustable that Recaro has...
or it has to be an OEM seat with airbag detectable cables? what other OEM/Aftermarket Power Seats would work with the Tacoma Air Bags?
I figured out the driver's seat air bag sensors. That was very easy.
The passenger seat has 4 strain gauges at each corner to measure the weight in the seat.
I was able to rig it up so that the airbag system would clear the self test, but there is no way it will fire the passenger airbag properly because it is not getting the correct weight reading of the passenger.
Anytime the seat is removed and reinstalled it is supposed to be recalibrated.
My airbag light has been on for a while too :hmmmm2: I thought it might be because I haven't reconnected the off-auto switch near the radio.
