SignUp Now!whatever looks good to you
i thought i read some of th e-gay stuff had melted in the past.. maybe i just confused myself i dunno. sorry
X-Caliber said:The retro fitting.. this doesnt involve any fab work does it? All I need to buy for my stock headlights are the LS kit?
The only thing you have to do for the LS kit is open your headlight housings and install the kit then reseal. If you can do the BHLM then you can install it.
Just make sure BEFORE you seal them back up...put them back on your truck without the clear lens on to adjust the "rotation" alignment (it's ALOT easier this way). After that's done you can seal them back up and do the horizontal/vertical adjustments once everything is installed.
