Sproulesxrunner
- May 11, 2010
- 3,278
- 2
How does it feel on the road now? Any differences in handling?
SignUp Now!do i just need 3rd member or entier axle housing aslo? OH AND WHAT IS TTORA?
the heads are 1700 with your chouce of cam. My tuner told me to get these and thats what he runs on his 10sec carhow much are those stage 2.5 heads, and are they better that patriot stage ii heads? I was also looking into afr heads but for $2500 i wish i could find out which head gives you the best bang for your buck..
From texas speed and performance. Not a matched set but its a heads cam package and you get to choose a cam or have one custom ground. Dont have to up grade anything. They come with new pushrods and springs. also gives you an option to add new timing set and ported oil pump. even adding those 2 options it is onlt 1900.00
yea all work except temp guage. it was ran off ecu. i have aftermarket on a pillar thoughDo you still have any stock functions left? a/c, gauges,etc.....
handles the exact same just dont have to bother with the clutch or changing gears. i must say quite nice.How does it feel on the road now? Any differences in handling?
thanks bro will do:top:come over to ls1truck.com know they would love to see yalls swaps and alot of great info over there
I went w auto because I am tired of shifting gears. I just wanna sit back. And cruise. Plus with a shift kit and srall it will shift faster than anyone can shift a stickAny reason u went with an auto trans instead of a T-56? Not knocking u at all because if the XRunner came with an auto trans option I woulda got that instead.
I would imagine the truck would handle better since the motor sits so low in the engine bay, lower center of gravity. Good to see u got it finished and running, I'd love to see that thing with a blower on it someday, it would be one sick as ride, not that it isn't already!
I feel exactly the same way about an auto tans as u do. I'm tired of shifting gears, the novelty has worn off in my 20's. My Dakota R/T was an auto(only came auto) and it had a shift kit in it, that thing was a blast to drive and would chirp 2nd gear when taking off at 1/4 throttle. Your right, with a trans set up with the proper stall converter and shift kit there's nothing out there that would be quicker then it shifting. My next ride is gonna have a big V8 with an auto trans, the only problem with owning an auto trans is that my wife would be able to drive it then:thumpdown:
