The Denso Irdium plugs last a very long time.
The electrodes do not erode like other spark plugs so the gap stays very consistent.
This is just off the top of my head, but based on a long talk I had with the Denso rep the Power plugs are advertised to last for something like 30,000 or 50,000 miles. The power plug has a very thin center electrode.
They have another version called the Long Life plug that is advertised to last for something like 90,000 miles. The center electrode is slightly thicker.
Now here is the real deal. That is all about marketing and an attempt to capture OEM contracts. You will get the same life out of both plugs unless you damage them with knock or something.
You can pull the plugs, check the gap, if needed regap them and return them to service if they are working properly and are not damaged.
Now when you adjust the gap, do it correctly, use a wire type feeler gauge and a proper gap adjustment tool. Do not use a coin type feeler and don't pry off the center electrode with a screw driver. If you do not have the proper tools or knowledge, just install a brand new plug.
The Denso Power Iridium plug is a super nice spark plug. We do ship a lot of them out the door at URD, but the down side for us is that you don't need to keep rebuying them.
