Ostrichsak
- Apr 21, 2013
- 97
I've searched and can't seem to find a write up on how to remove the s/c to get to the passenger plugs in order to change them. Strange because I can find detailed write-ups on doing plugs w/o a s/c which seems pretty straight forward but not quite the same w/a supercharger. I read something about unbolting the intercooler and letting it hang and when you unbolt the s/c just move them both to the side to keep from having to disconnect the supply lines.
Anything I should know or just start unbolting? 14mm ratchet on the tensioner nut and then CW or CCW to loosen (I found conflicting information on this step) the belt and I'm guessing I don't have to remove entirely, just from the s/c pulley and use something to hold it tight but out of the way so I don't have to mess with re-routing? What size bolts am I looking for, how many and what is the torque specs for them when I'm done? I just don't want to unbolt a bunch of stuff I don't have to trying to get this thing off. I'm fairly mechanically inclined with plenty of tools but my truck was already s/c'd when I bought it so I don't have any experience with installing it to draw from. Maybe once I look it over it's pretty obvious but I just wanted to make sure I've got my ducks in a row before I get started.
I'm going a smaller pulley at the same time so I'll being doing the steps required to change that out too.
Thanks for the help.
