blackx-runner
"White Flash"
- Jan 14, 2007
- 7,581
- 13
flow matched is the way to go.
honestly, at 30K or 60K you really should not have carbon build up on your injectors unless you are running super crappy gas or your driving style is a very short duration in very high temperatures. So you are really wasting you money cleaning them that early. Toyota recommends it to cover the masses, included the people that will put any gas in it with any wonder additive off the walmart shelf. If you are running premium, top quality gas, you should have little to no buildup on them, or the valves.
sending them out to get "serviced" is also a crock. A inlet filter of an injector has to be 70% clogged before you will see any difference in the performance of the injector. And I am talking 70% completely clogged.
There is also no way to " flow match" your injectors unless they are matched when you send them in. There is no way to change the injector calibration once they are built. The only useful info that you get from this is which injectors are rich and which are lean. and you can use that info for placement ( example would be LS motors in which certain cylinders run leaner than others due to poor stock intake design.)
When you send an injector to be serviced, they change the inlet filter ( if applicable), put new o-rings on, soak the tips in acetone and then operate the injector independently in top engine cleaner ( or some other solvent). Honestly, the tip soak has the most impact if the injector is really coaked up.
but what do I know
Justin
You probably haven't even seen a fuel injector before. :rolleyez:
You just googled all that info, not like you design and test these things for a living :biggrin:
