This is a question I got abotu LS Halo Kit that Im selling
" have an 09 i have the day time running lights, so do u know if the halos will run with those or only with the running lights turned on"
my answer
I looked at the instructions and it looks like the Halos are wired into the side marker light. So if your side marker lights run with you daytime running then they would go on. Im going to post something on XRU to see if Im correct. Im not sure but if you tap into another power source or run a seperate switch to the halo you could turn the halos on and off as you please.
Don't know much about 09's or the Halos so just wonder Im giving the right info. Also not sure if I posted in correct area please move if needed.....
my answer
