babyboi2284
BaggedXR2284
- May 23, 2010
- 3,968
- 4
Im not totally sure yet but maybe in the next month i may be joining the F/I group and im curious as to the options everyone has. If everything goes right im gonna get the TRD s/c so it can be under warranty and keep my truck warranty. This is the info i got off ebay for the parts that come with the kits they sell. Im gonna get the kit from the stealership so im guessing their kits will be the same. My ?s are 1)are there upgraded parts available to the stock s/c kit parts and 2)where do yall get them from? Im sure the x-1 is a good thing to get but i think i read they are still on back order or something. The kit and install is gonna be a nice chunk of change so what other decent mods can i get with it (that doesnt come with the kit) that will make a difference? Any info will help.....i wanna do it right for spending this much money.
FROM EBAY SITE---
The TRD intercooled supercharger system kit for the Toyota Tacoma 4.0L V6 engine features an air-to-liquid intercooler that increases torque and horsepower from idle to redline, delivering immediate throttle response, along with substantial increases in acceleration. The system uses a strong, compact one-piece plenum/manifold that integrates Eaton Roots-type rotating components, Gen 5 rotor pack and the heat exchanger core for the intercooler.
FROM EBAY SITE---
- Features air-to-liquid intercooler with a low-temperature radiator, coolant reservoir and circulation pump, delivering improved engine response and power output.
- Intercooler provides higher performance and better fuel economy, as well as improved passing power than non-intercooled superchargers, restoring sea level performance when at altitude.
- Produces 304 hp @ 5,400 rpm and 334 lb.-ft. torque @ 3,600 rpm (from 239 hp @ 5200 rpm; 278 lb.-ft. @ 3700 rpm.
- Uses Eaton Roots-type rotating components in a compact one-piece, supercharger plenum/manifold casting that integrates the heat exchanger core for the intercooler.
- Integral by-pass valve prevents supercharger from going into “boost” when driving at a steady state of speed such as on the highway or light traffic. Takes less than ½ hp to operate when by-pass valve is open, helping reduce parasitic drag from the crankshaft.
- Kit includes new 455cc fuel injectors for the increased power output, iridium spark plugs for better detonation resistance—ensuring proper fuel delivery when using supercharger system at full capacity.
- Integrates factory calibration of ECU for optimal fuel mileage when combined with torque/horsepower increase.
- All OE hose connections accommodated and OE throttle body bolts to original location.
- Complete kit includes all necessary hardware for “factory installed” appearance. No cutting, welding or fabrication required for installation.
- Supercharger has self-contained lubrication, so there’s no maintenance required on supercharger—or supercharger system components.
- Emissions legal in all 50 states.
