So does anyone have one. If so, can you post pics of installed? I have a used kit that I bought for my other car and planning to install that into my X Runner instead. However I would like some feedback from others on location of Methanol and etc...
SignUp Now!i've asked about it several times... the verdict i HEAR (note, not my own opinion) is that it's more risk than it's worth... i dont personally know, and to be honest, i'm still interested in it myself.
without tuning it is pointless
urd sells aquamist kits.Just curious of why do you think it is pointless? Having more octane is pointless? Granted that with tuning it would be ideal, but my point is more of protection instead of power. Besides, methanol don't make power it only allow you to boost more. Better yet, next time you are on the dyno tell them to turn the fan off. Because having the fan there is pointless.
Protection from what? Well there are so many factors that could go wrong in FI...Boost creep (not much of a factor in supercharger), bad gas, temperature variations, etc...
I know Methanol injection might be new to the X-Runner crowds but its the norm in the Domestic. Here is just one of the MANY links about Methanol. I was hoping someone have one installed so I can see what I can be expecting.
http://forums.corvetteforum.com/c6-forced-induction-nitrous/2264410-meth-injection-on-a-maggie.html
I believe that SUPERWERTY AND SPYDER327 from AZ are running these. Pretty sure SUPERWERTY has the AFR.
A safer alternative to this would be to add the 670cc e85 injectors, upgrade your fuel pump, and the add the APR 7th (which also has a 670cc e85 injector)
This setup would allow you to run e85 all the time, and your cooling effect (which is what you really need) would be all the time. You would not run the risk of your Meth pump breaking or running out of fluid and causing horrible damage.
Also, you would have full time 110+ octane fuel, and e85 is a better cooling agent than meth itself.
Not to mention, your gas gauge would indicate how much fluid you have, being that it takes it from the same place your injectors do. No risk of pump damage or running out of fluid. Win-Win
