SIK X
- Oct 22, 2009
- 422
First.. this is what i have on my truck..
900hp Capable turbo kit on Stock Un-Flashed ECU and stock injectors @ 5psi. making 315hp 360trq
Fuel pump
ACT clutch
DOT drag radials 275/60/15 Mickey Thompson
And thats it!
my previous best was a 14.0 during texfest event. I had no trans problems then. and on stock clutch and tires.
I was getting very upset Saturday cause my trans would not let me in 2nd gear. It seemed the harder i launched it the worse it was. During normal driving conditions it shifts just fine. My shifts were very slow (if at all) and i started launching softer so that it would go in gear. Maybe some of you would know more about this. I Know i need a traction bar, and while im at it im going to make stiffer motor mounts. We think that cause the motor, trans and rear end were shaking so hard it was locking me out of 2nd. I dunno, Im going to add these parts and see if im still getting the same problem with my drag tires. On my stock tires, this does Not happen.
Otherwise I guess im still happy with these numbers. 13.8 was my best, with 1.9 60ft. One of my runs i did get a 1.72 60ft, but i got locked out of 2nd. Without the trans issue I know I could have done a 13.4 or .5. maybe next time.
So my question to the XRU crowd......
Do you think stiffining up everything will help my trans shift?
And Am I the fastest XRunner on stock un-flashed ecu?
Fuel pump
ACT clutch
And thats it!
