Edgeman
- May 17, 2008
- 1,029
- 26
Engine Masters had a naturally aspirated LS-3 on a Dyno at Westech, and decided to test 87 and 91 pump gas from a gas station down the street from them, as well as Sonoco race gas in 110 and 116 octane levels. There was no noticeable difference in power between any of the fuels. E85 did make a little more power across the entire curve. The first four fuels also liked the same timing...I think they said E85 liked a slightly different timing.
Bottom line: you aren't going to make more power by putting in higher octane fuel. You just need enough octane to prevent detonation. I've read that we may make less power running 87 because the knock sensors will detect detonation and retard timing, but you won't gain any addional power by going higher.
Now if you go boost...
