Well, my first clutch died early. It was around 50 to 60K miles I think. I had the original LUK clutch that came in my 05. Every Hub spring was broken in abour 5 places. No biggie. I replaced the pressure plate and Disk with new Toyota / Aisin parts (07 model stuff). New disk had beefier springs, bump stops and the pressure plate looked a bit more rigid as well. Well, this morning with 70K miles on my Odo., Clutch failure. MY truck now has the aluminum flywheel, and Poly filled TRD shifter. (note, I beat on my truck HARD). The hub on the new clutch actually RIPPED away from the clutch disk backing plate.....WHOLE THING. BIG ROTATING CIRCLE. I do a lot of clutch kicks and such around corners and when I am just tooling around, but it has become VERY apparent that the factory clutch was not intended to put up with that kind of abuse. Looks like I am going to have to go aftermarket if I want to continue to play.
Word of advice, if you do burnouts and clutch kicks and beat up on your truck a good bit, go ahead and buy a GOOD clutch, even if your stock one holds the power.......it will fail one way or another .
