Damn. Look at all that open space you could play in! Wish we had that here. Nice photos too. It Looks super hot there lol. Thank for the vid. I'm glad you got your catch can figured out. I'm running mine the same way as well with no problems.
Yes, it feels like Mars. Literally. Not that I've been to Mars, but I think it does. No life, nothing, just plain open spaces. Then you stumble upon those amazing and massive underground caves.
I find that I get a lot of engine oil smell with this catch can setup. I am thinking of using a hose to relocate the crank case breather to vent to someplace where I can't smell it.
I actually owe Torspd an apology, the pressurizing of the crank case was not due to the failure of the check valve, as I thought initially. It was a result of improperly routing the vent. At WOT, the intake boost is keeping the check valve closed, while the crank case is trying to push air through into the intake to relieve pressure, but because of boost the check valve was closed shut resulting in a pressurized crank case.
Elite Engineering recommends connecting both exit ports (my catch can has two exit ports, one of them is closed). One that goes to the intake plenum post-throttle body, and the other goes to the supercharger inlet, pre-supercharger. Both lines should be equipped with a check valve. What happens is the exiting air alternates between the two, when there is vacuum it will be going into the intake, and when there is boost the supercharger would be doing a lot of sucktion creating some vacuum, and at that point the air would vent to the inlet of the supercharger. Apparently doing only one without the other will result in a pressurized crank case.
I'm surprised at how much piston blow by there is, I didn't think it is that excessive. I'm sure it isn't worn piston rings, because I'm not losing engine oil at all.
