SignUp Now!Looking good man.
one tip for you put the coolant tube back before you put both heads on.
LOL. I'm guessing that happened to you? Learned That one pretty quick. Was trying to take it off with the heads on and found it wouldn't slide out. :/
Ok. I'll text u when the time comes.no didn't happen just throwing it out there for ya. also if you need any torque specs. or timing or anything let me know i can send you diagrams
Rebuilding the engine ain't bad. I done mine myself and its been good so far. Cp Pistons and molnar rods. clevrite rod and main bearings. Oem trust washer. gauge or cylinder bore gauge. Torq wrench. And Id go new crank seals. An full gasket set. Ull be ready to put it back together beside getting the crank balanced.
Is balancing the crank required? Been reading and been getting different answers. I know torspd didn't do so on his first built block. I asked a mechanic here locally and he said it isn't necessary. I just want to make sure I do this right the first time.
Where'd y get your full gasket set? I think I need a new timing chain kit too. Tensioner on the driver cams are shot.
Did you get the dyno files? If so send them to me and I will make that chart look much nicer for you.
