When you ran the stock injectors, did you reset the ECU by removing the neg bat terminal for about 10 minutes?
If not, the stored fuel trims would make it run super lean with the stock injectors.
If you did not reset it, I would reset it and reinstall the stock injectors. Lite it up and see where the fuel trims trend to once it drops into closed loop.
