SignUp Now!...Sdxrunner is the man. :adore:
No worries bud, I just want to see if our cal Id's match before Toyota calls me back
If you guys have the same Cal ID, how is doing that test going to confirm anything other than they did the 90l? It's not going to confirm the re-flash either way (or any more than your match cal ID would).
Calibration is, according to techstream, 3ywg1800
Gotcha :top:, in a post of his a couple back he said you guys had the same ID.
Has there been a new install guide issued? Would be terribly frustrated if my instructions told be what ID I needed and it was not longer available.....
They don't. My Cal id is the reflash id. The one I posted earlier. 3ygxxxxx...on my phone, I can't find that
05-08 trd reflashed trucks will all have the same reflash id. I wonder what they reflashed on your truck, maybe it was the 90l. I need you to get in your truck, getting going over 30mph, then hit the gas and brake at the same time.
Your truck should just shut off. That will confirm that all they did was the 90l.
That makes sense now, that's why I'm running rich, my ltft is roughly -20 to -30. I bet they did the 90l and not the trd reflash. However if they didn't do the trd reflash then there would be updates available for it and they are stating there is not.
Yes I was confused when Kevin posted my cal Id and thought he was saying that's what was on his truck. Also the trd instruction manual cal id matched the cal id that is in Toyotas tech stream system so the cal id has not changed
So if there's anyone that's had the 90l done and not s/c I would put money on it that the cal id's match. Has anyone had the 90l done and not supercharged?
That's right, I guess I need them to get me a new ecu With the correct trd reflash done correctly
