ramsey422
- Jan 14, 2007
- 317
hay raversman all you have to do to get the remote start to work is disconnect the clutch start switch (neutral safety switch). it is located behind our clutch pedal, if you watch when you push in your pedal if you look towards the top of the pedal you will see a switch located on your firewall, that when the pedal touches it starts the truck. then just disconnect it. You might want to try it out first too make sure it want through a check engine code (it should not). but if you forget to take it out of gear when you park it, hate it for you cause the truck will go or jump forward
So if i wanted to start the truck without using the cluch, i can remove the neutral safety switch? I never park the truck in gear so im not worried about that, just would be cool to do one less thing when i get into the truck.
