SignUp Now!I have the Competition Clutch Stage IV with the light weight flywheel.
definitely more zip during acceleration. More aggressive bite on engagement. Real easy to chip tires during shifting.
Biggest improvement is normal shifting and gear engagement compared to the clutch assembly I had in there before. I am much happier about that.
If you are chipping tires you have some issues gadget. Must be all that URD power ripping the rubber away from the belt.
just a heads up on install guys.. ensure your flywheel is perfectly pulled up on your crank.. triple check torque and triple check you clutch.. its gonna require some extra effort.. but you dont want to pull it down again..
funny how the world works.... at first smooth as silk... now the viberation is back.. not as bad as before and its only down around 600 rmp's.. im going to assume this viberation is normal..
I learning the clutch.. seems you really have to rev to about 1500 or so to get a smooth take off from a light.. I've been very easy on it.. I now this chatter should work it self out.. any way right now I love this combo after Im rolling..
I will tell you my 1st gear is useless. if I get on it (not floored) in 1st I light them up.. I can see if I was on stockers 2nd would do the same... I guess we will see how things work out.. Im not pulling it apart again..
flywheel really allow the truck to rev WAY faster.. clutch grabs like crazy..
yep...welcome to the club.funny how the world works.... at first smooth as silk... now the viberation is back.. not as bad as before and its only down around 600 rmp's.. im going to assume this viberation is normal..
