Super Werty
- Jul 12, 2007
- 6,283
- 4
lauch in 2wd and Ill show you slow...
lol, if you guys only knew
SignUp Now!lauch in 2wd and Ill show you slow...
looks like mines 185
why is the sky blue?Why are your rpms going down, when you are at 100% throttle (5950rpms down to 5411rpms)?
TPS on that shot is 100% all the way across.. means WOT. During WOT, your RPMS don't go down...
The chart is indicating a speed shift just occurred.
If it was in fact a power shift, then a bit of false advertisement on Steve's part.
Whats the load you were making during the actual pull? I'd guess around 160-165%..
Below is what I posted..
Another post
Please explain how its false advertisement... never said what the log represented...
You Slander much? (Slander- a malicious, false, and defamatory statement or report: a slander against his good name. )
Ok this ones for u DS 158.3% air load with URD 2.85" pulley:top:
No need to get your little panties in a bunch. Grab a hold of your balls man, stop getting butt-hurt over everything someone says. You been getting all pissy lately. You need to chill out.
Your post was made to give the impression that you were making 180% load in regards to a pull. You omitted the little fact that it happened in between gears during a shift.
Hell i've seen N/A trucks hit near 130% that way. :rolleyez:
That's sexy! I bet the truck pulled like a monster during that pull.
What was the MAF on that run? I'd imagine it was in the 340-350g/s range.
Xrunnit- this truck always pulls like a motha phucka:top: as soon as I get my 7th and 2.7 or nst od it will be right where I want it!
DS didn't believe me I pulled around 160% with a 2.8 pulley, it's cold as phuck in Jersey so tha powa is to be made:biggrin:
Not sure what the MAF was? My buddy had to email me the air load log
Ok this ones for u DS 158.3% air load with URD 2.85" pulley:top: I knew it was close to 160%
U asked for it and I showed u, must be talking bout Jason and Steve with the pee pee thing:crinklehair:
pm me ur addy again, can't attach anything to emails on here, unless u can and I don't know how?
May I suggest not using aluminum rivets
