Hey gadget,
I recently purchased a 94 4runner from my friend that I helped do the 3.4 motor swap with trd s/c along with the urd fuel kit, and is running the 2.1" pulley back in 2006. Anyways, it ran great for 2 years and put 20k miles on the swap. It then has had some issues over the last year or so, and wasn't hardly driven since.
On the ftc the map originally started with 9.6 value then was brought down to roughly 8.x maybe lower I don't remember as the boost went up, but it is now running lean with high egt temps.
I have since installed the stock pulley back on the supercharger and have added more fuel with the ftc. the numbers start at 10.1 and go up to 10.7. Is it normal to have to go above a value of 10 on the ftc with just the stock pulley installed? EGT's and AFR readings have since come down to safer levels, but still need some work. Could I have a bad ftc? Maybe a clogged fuel pump? I just changed the fuel filter for the heck of it. The truck starts and runs great otherwise while cruising not in boost. Today I was doing some tuning runs and when the truck enters open loop afr's are 11.5-7 with EGT's at roughly 1200 give or take. 600-800 at idle, and vary between 800-1100 in normal driving conditions depending on load.
I have the scan tool that shows the fuel trims. I make changes to to cells that need it as needed to help with the lean conditions and get the trims as close to zero as possible. It also has the AFR calibrator installed with the stock unmodified map loaded currently.
I can call you later, but wanted to post here first.
